Denon 1909 + which speakers????
girl21
:confused::confused:
i have seen the denon 1909 today and found it good but the cost in mumbai is Rs.43000/-:eek: can i nego with profx? or do u know any other dealer in mumbai?
in speakers my option are but still a bit confused between the below mentioned:
- Wharfedale Diamond 9 HCP
- Polk Audio
- Focal
- Jamo
Do you any dealer in mumbai who can give a best price combi???:) EMI Option is best for me
(i had planned for onkyo HTS 5100 but:rolleyes:)
The diamond 9 HCP is good option. Alternatively look for Tannoy SFX 5.1. Great option compatible with blue ray cause has wide frequency response.
Also look for Onkyo 606 or Yamaha 663. excellent amplification for your money cost just 36000.00 better service that Denon in Mumbai
- Polk Audio
- Focal
- Jamo
Hi, once again on HT talk.I thought you decided Onkyo3100.
I will advise to check in Soundout- Heera panna at Mahalakshmi.
I went there 2 yrs back when he offered me Denon 1706 for RS.18000,
and actual price at profx was 27000.It was a grey product.
Dont worry,he is even dealor of wharfedale,Yamaha,Deftech.
Warrenty may not be problem as you can check Denon before buying.
Secondly in case you get problem it may be minor & corrected with
spending few more.(profx gives service)Still you can save money for cables.
