denon AVR-1910 + Q Acoustics 2000 Series Cinema Package
atulpilot
Pune
hey guys i am planning to buy the new denon AVR-1910 + Q Acoustics 2000 Series Cinema Package with additional 2 surround speakers 2010 to make it a 7.1 system.
denon 1910
front
back
will the two match properly???
what can be the lowest price i can seek for the two in mumbai.
is it worth buying the speakers from the grey market herrapanna.
i need suggestions regarding more combination.
also is it possible to create a 9.1 setup with this receiver as it has dolby prologic IIz???
my room size is about 12x10feet.
thanks in advance
I think you can use any of them at a time, so thatz not possible. I have a Denon-790 which is same as Denon 1910.
Anyway, this receiver rocks, good upscaling capability!:clapping:
Well, my friend has this same package. and I bet its one of the best Cinema Package u can get.. If yr room dimension is 15 by 10.. 7.1 will not be suggested. go for 5.1 package with Denon 1910.. BTW where r u getting 1910 now... as 1911 and 1912 are in d market
This is a two year old thread.:D
