denon avr1908 crossover settings??
insane79
Bombay
hi,
i love my denon 1908 :) sweet stuff, i m confused with the advance crossover settings, audyssey did a good job with the speakers size & measurements but didnt do the crossover properly :( i want to set the crossover sep for each speaker,
these are wat i use for my front speakers-
S 600
center-
S 600
surrs-
S 600
subwoofer-
Subwoofer line
wat ur'll guys suggest?? thanks..
hi,
S 600
center-
S 600
surrs-
S 600
subwoofer-
Subwoofer line
Simple tips-
1.Sub setting- keep crossover @60 if your sub can go deep.If fronts are not
capable of handling 60hz,then keep setting above its lowest frq response.
ie.fronts 80hz to 20khz,keep crossover 90 or 100hzs.
2.same rule for other spk too.
You have to play it by ear literally. THX recommends 80, but in some entry level HTIBs from Onkyo I have found 120 to be the best but generally between 80-100 works best.
