Denon PMA old series loudspeaker terminals
HiFiDave
Berlin
Hello to all HiFi lovers. As the first post of mine here I would really appreciate if I found the answer to this question. I'm intending to buy one of the Denon PMA series. It can be PMA 860 , 1060 , 1080R , 915R. I have pretty good Speaker cables that are terminated with banana plugs. I always tend to connect with those type of terminations. The Denons I have mentioned here have Speaker terminals that seems not to be banana types but they have small holes inside so they look as they have caps in them. On some other Pictures the same Denons have typical banana plugs I mean the same models , I am pretty confused - did they produce the same models with different terminals ? Please answer if man can take the caps off the ones that have the small holes inside ( they do not look as if they were banana plugs ). In case they are not , can man put banana plugs through diagonally ? I try to attach some Pictures.
Regards , David.
