DSP for Subwoofer from Dayton
ankitbhargava
Udaipur
We have heard a lot about MiniDSP already, many of us are using it as well.
Here is a simpler and less costlier solution from Dayton
Also available via Desert Cart in case anyone wants to try it :)
Specially suitable for single sub setups
Wanted to open this discussion for any FMs who have already tried it or want to try.
You get one output with this for Rs.6,665. This is the cheaper option ONLY if you need one output.
MiniDSP is with 4 outputs, and is available at Rs. 8,900 with the same vendor.
+ Umik + time spent on REW
This should be easier solution specially of it's about single sub setup
