sorry to say that I could not take pictures with a high quality cam. I don't have one currently. I took the above pics with my mobile redmi note 3. The actual quality of the image is definitely better than what you see here.
screen (wall presently) etc....
I am getting 8 feet wide picture easily. Its a great experience to begin with ...
EGATE P513 is surely very good in less than 20k price range.
There is some stuff in my room that I have to move out... to make it a dedicated HT room.
And instead of buying a rack or cupboard, to place my avr, amplifier etc, i taught of building one.
May be this is a bit off the topic, but I bought two sheets of 12mm glass 4x1.5 feet.
I have to make a stainless steel or wooden frame to mount them...
But meanwhile, I got a temporary cheap idea.
I cut 50mm thick thermocol sheets into multiple pieces, and placed the glass sheets.
See the below pic...whatever little we do... a diy gives some satisfaction...hyeah:
Il think on the extended warranty elangoas... i guess il go for it..
And right now i cut the thermocol pieces around 6 inches wide. If i replace them with a thin stainless frame, il get plenty of space.
And i can add one more glass on top and make it 3 tier if neededhyeah:
Cool..
I hope you will be projecting on the wall behind the glass stand.. If you add one more sheet of glass, you will need to place center speaker above that and the projected image has to start above that.. Juz measure approximately (projected image) on how much height it is going to be from your seating position.. (Caution : not to strain your neck)..
If I add a screen, I can place my center channel behind it. (Not sure if the volume gets obstructed by the screen. May be it will be minimal.)
If I continue to use the wall, I have to place the center channel below the screen. Not ideal, but manageable.
With my little experience, I felt that screen is better if it is as near to the floor as possible. May be 1.5 to 2 feet above the floor would be good. (in general, our eye sight is more comfortable looking down, than looking up)
Just to keep my kid safe, may be I have to place all my AV stuff above that corner box. I can build a rack above that though ..
If I go for a screen it will be a DIY. Its fun.
And I have your thread to copy all the things you tried...hyeah:
Making a large screen flip up, will make my wife go crazy.hyeah:
She is already frustrated that I am literally living in that room :lol:
My glass rack happiness didn't last for long.
My one and half year old daughter wont sit any where in the house except on the glass rackhyeah:
And she started scratching the thermocol already.
But I am more worried to have all electrical connections in her reach. So last night I moved my AVR to the top of the corner rack i made.
It was made to keep laptops and laptop bags. :sad: Few months ago I didn't had a slightest guess of buying a PJ. I wouldn't have put the rack there.
My wall is 10feet 2 inches. And the rack is little more than 1.5 feet wide.
Any way I have only 8 feet wide usable wall.
