Emotiva@ enigma/confusion
friendshpbells
faridabad
Basically I am looking for EMOTIVA PREPRO AMPS WITH A CDP AND A BLURAY PLAYER(HAVE SONY BDP@9900).
Audio preference (Music / Movies) = 50% / 50%
2. Budget = 60K-100K {can be ferried by near ones in us}
3. Room Size (Lenght x Breadth x Height = 16 x 14 x 10(ALL IN FEET)
4. Source (CD /DVD /Satellite /Other) = AITEL DIGITAL TV/SONY BDP/SONY CDP(OLD WITH OPTICAL OUT)/AITREL DIGITAL TV(WILL UPGARDE WTHEN DVR+HDBOX IS AVAILABLE)/IPOD
5. Existing components to be integrated with new purchase BORED OFF WITH MY OLD CREATIVE 5.1 SPEAKER PACKAGE
WANT TO CHOOSE BETWEEN WHARFE 10.7/MS AVIANO 8/ELAC 127FS..ANY OTHER LOGICAL SPEAKERS IN 120K RANGE FOR A 5.1 SYSTEM
6. Can used AVR be considered (Y/N) = YES
i am really in a confusion about what to order..........
can i get some hands on technical advice,expert opinion and rays of illuminance from all the music gurus here on the following few points
i consider myself to be a audiofile
i am into music and movies(50% each)
there were a few combinations i looked at
1. for a stereo setup @1660 dollars
($399)ERC1- CD PLAYER+
($399)USP1- STEREO PREAMP
($799)XPA2- STEREO POWER AMP 2 CHANNEL
300 watts RMS x 2 into 8 ohms
2. for a movie 7.1 setup@1450 dollars
SOME BLURAY PLAYER
($699)UMC1- PREAMP WITH VIDEO UPSCALING
($699)UPA7-POWERAMP WITH 7 CHANNEL AMP.
125 watts RMS x 7 into 8 ohms
1 want a rig for both way for music and movies
option a:7.1 setup@1450 dollars minus the cdp
continue with package 2
SOME BLURAY PLAYER
option b: 7.1 setup@2120 dollars minus the cdp
SOME BLUERAY PLAYER
($799) XPA2- STEREO POWER AMP 2 CHANNEL
(left and right floor standers)
($549)UPA5-POWERAMP WITH 5CHANNEL AMP
(centre channel,surrounds)
125 watts RMS x 5 into 8 ohms
optionc:7.1 setup@2100 dollarsminus the cdp
SOME BLUERAY PLAYER
($599)XPA3- STEREO POWER AMP 3 CHANNEL
(left and right floor standers,centre channel)
200 watts RMS x 3 into 8 ohms
($349)UPA2-POWERAMP WITH 2CHANNEL AMP
(surrounds)
125 watts RMS x 2 into 8 ohms
(surrounds)
optiond: 7.1 setup@1925 dollars minus the cdp
. SOME BLUERAY PLAYER
($599) XPA3- STEREO POWER AMP 2 CHANNEL
($549) UPA5-POWERAMP WITH 5CHANNEL AMP.
(surrounds,one channel free)
AT TIMES I FEEL TO ORDER UMC1+UPA5 AND HAVE A LISTEN AND THEN GO ABOUT ORDERING A XPA2/XPA3/UPA3 AS PER THE AUDIOFILE PLEASURE THE UPA 5 DELIVERS...
what is the difference between a stereo2.0 and a upscaling 7.1 preamp and can the 7.1 preamp used for music without much appriciable loss of detail
SHED LIGHT MY FRIENDS.....
UTTERLY CONFUSED
suggest me the best possible combination that you would suggest me for my liking,the goods will be delivered to me by my friends@us
thanks
dr.abakash mohapatra
For your room 7.1 is not nessacary. I would go with 5.1. Try to buy better speakers and better amps. If not you can postpone your surrounds for now and just by xpa 3. May be a year or six months later you can add XPA 2.
Most important, Pick the best speakers you can afford. All of the other things come next.
If you are a looking for a killer pre pro and can afford to wait for some time you might want to look at Marantz AV 7005 due in Oct 2010. I too was looking at UMC 1 at one point, but this one looks so promising
