Eversolo DMP A10
Looks like a damn good piece of gear. Has anyone looked at this offering from Eversolo?
Link: Eversolo DMP A10
that Display in the volume knob is cool. Overall it looks distinctive. Kind of a departure from their minimalistic design though! And the price is around 4 lakhs! The matching power amp also looks cool
Eversolo is nice as a transport but pretty poor as a dac. Atleast this is my experience from an A6 Master edition.
The higher end ones might be better as they have more elaborate power supplies but for a pure DAC, I would look elsewhere.
I feel it is better to keep the dac and streamer separate as the latter will keep getting updated and improved on at a much higher rate than the former. I like to hold on to my DACs for atleast a decade. Pay once and then forget about it.
After looking at the A10 I was informed that the A8 is no slouch and at half the price.
I was thinking of starting another discussion on it but will continue on here for now.
Bonus (for some) is that the A8 comes with AKM DAC chips
yes looked at the offering, looked so promising then I looked at the price and the I looked at the bank balance and then I cried lol. Jokes Aside this thing is going to look killer with the matching amp.
Initially I bought A6 later upgraded to A8. I'm happy with A8.looking at the price of A10 I can't venture another upgrade.
I'm happy with A8
recently I swapped the company's power supply board in the A6 master editon for a friend with one he had imported (dont remember which one). It was a worthwhile upgrade and he is now using it as a transport-cum-dac.
Does anyone know if you can store offline music from Spotify/Apple music on the internal SSDs of DMP A10?
I'm happy with A8
Hi, I have an A8 too, do you use a separate DAC for this..I don't at this point and have a Hegel H390 amp..
Any compare (by forum member or on You Tube) ......with an equivalent product from Lumin ?
Would be interesting ....
Having heard both brands, IMHO the Eversolo A6 Master Edition and the A8 are both comparable in sq to the Lumin U2 mini. Eversolo scores on features and interface, while the U2 mini has a slight edge in sq. The Lumin U2 (not the mini) beats them all by a mile in sq. The Eversolos have a built in dac which are quite usable, but if one is chasing high quality audio, an external dac is needed.
Cheers!
Not equivalent products. However, I have owned both a Eversolo A6 Master Edition and Lumin U2 Mini. Used as a transport, the Eversolo was a disappointment - it carried over its strident personality even when used as a transport. It seemed to be at the presentation level of a Bluesound Node. The U2 Mini was a step up, but not a big one. It has an edge in things like soundstage depth and midrange resolution.
My general conclusion from fiddling around with all these is to not bother unless the rest of the setup is resolving enough. A bluesound node with an LPS mod can scale to a reasonable level with an external level. For speakers like the Kef R3 Meta or equivalent, this is enough. Things would be even easier if the Wiim Pro also scaled as much. Unfortunately it doesnt
The issue in these eversolo devices is the android operating system. If the OS becomes outdated and the company stops updating, eventually, the app support will also cease and rendering the device useless.
True. Google has the habit of dropping support for old devices like hot potato. Once that happens there is not much the Chinese can do. Users will be forced to deply hacks to install android images from leniage, sailfish, etc.
Sorry, I am not familiar with the Upgrade aspects of Android....
ajuvignesh & mbhangui... Can you please explain ...
Wont the Eversolo devices continue to operate indefinitely, in their last installed / updated version of android, even if support for older android devices is stopped ?
What they meant , As of now , hardware supporting upto a particular android software version would be fine, but once company or hardware gives up on software updates, no more upgrades/bug fix would be possible further. And if there bug found at that point, no more resolutions.
