F&D V520 2 Channel Multimedia Speakers
moday
Delhi
I am planning to buy the speakers for my main TV. In that connection please advise if F&D V520 if would be good enough for watching movies and TV serials good clear quality sound?
I do not want to spend lot of money on the speakers right now as I anyway planning to buy 5.1 HD speakers by mid of next year.
Do recommend if there are any other model I should consider....Thanks
The clarity is good and amazingly there is bass in them too.
However, they are more "personal" speakers and good for use with laptop or desktop PC. You cannot really drive them loud and I would not recommend them for TV. Only recommended if you are watching/listening from a distance of 2 feet or so.
For your requirement save up for a HTIB... a decent one will cost around 20-25K.
