Feee calling using android phone
kaushik
There are many push-to-talk android apps there for free
I have recently tried one called Virtual walkie talkie ,works nicely
Needed all parties have an GPRS enabled android phone [others ?]
-It gives you 40 channels , no special setup needed .
-If you want you can put a nickname
so that frenz can determine you are online.
- just install it ,select channel say 20, tell frenz to select the same
touch onscreen PTT and talk [release after talk]
other guy will get your voice message
Just GPRS cost , nothing else.
- Just the default server is public
may be good for situation like some one is going for market , wanted to ask many stuff
, meeting frenz , saving on STD etc
