nanzer
I'm considering my first build. I'm very new to the community, and am planning on sourcing my parts from Aliexpress (unless they can be obtained cheaper in India?). Currently just planning on a 2.1 channel Amp with atleast 60W of RMS power and minimum distortion. Not sure what impedance load I'll have - I plan to build HiFi speakers in the future, but currently have a 2.1 Boston MCS100 set or 3 Ohm Sony tweeters to choose from.
I've encountered the following ideas so far:
1. Gainclone based on LM4780 (which is basically 2 LM3886's in 1 package) - 1 for Stereo and 1 for Subwoofer. (Rs 2000 each) I plan to couple it with an LM1036 Tone board. (Rs 700) Power will be supplied by 2x 28V SMPS power supplies attached to each other to form a sort-of 28-0-28 pre-rectified system. 10A each supply. Also, I don't understand how nesting works, how can I couple it with an Op Amp for better quality sound? And how much more will that cost if I do it?
2. TPA3116/TDA7294/other Class D amp, again sourced from China. I'm not sure why some people say Class D sounds bad and why it's cheaper, produces less heat, but isn't used in top HiFi builds (to my limited knowledge)
3. The RX-V795 that I'm replacing has 84W Transistors inside it. Would using those or similar ones provide better quality sound?
Just to clarify, I'd rather use or modify a pre-assembled PCB than design/solder my own. Power will be provided using an SMPS, voltage and current is not an issue.
Thanks a lot for your help
Abhayraj
PS - I live in Chandigarh.
Abhayraj
