Fixing Dust cover cracks - Help
greenhorn
Thiruvananthapuram
The dust cover of one of my TT's cracked during transportation - this is at the place where the hinges connect. Cosmetics are not a big deal, but it needs to be strong as the weight of the cover comes in that area. Is a good cyanoacrylate glue (loctite 406 etc) good enough, or should i try epoxy (araldite?)
not looking for anything fancy or imported - something i can buy in india
Auster
The loctite should work better but it purely depends how it has cracked
