Fixing tiny pin holes in speaker cone and tweeter domes
goodyet
India
I have a pair of two year old Pioneer BS22 bookshelf speakers. Today I found that ants / insects have dug a few holes in the driver cone and tweeter dome of one of the speaker. The other speaker is intact. When I compered the SQ of both in isolation, I found that the speaker with holes gives less bass / thump than the other one. I want to fix the holes in a DIY way. After searching for solution in other threads in this forum, I found that I could use either fevicol fabric glue or silicon sealant to cover the holes. I want advise on what is the best way to fix the holes.
I am sure you would have read online and through various forums is to possibly get the cone replaced from the authorized service center.....
Doing a patch work using fevicol or other adhesives may just worsen the SQ
