jtaylor991
Hello! I'm new here, and this looked like the best place to ask this, so here I am. I'm jtaylor991.
So I've been ripping my CDs in Flack Compression Level 0 forever, and I have also downloaded FLAC from Bandcamp.com. So I have a mix of compression levels, most likely.
I decided I might as well save the space and compress further. So I fed my entire FLAC library into dBPowerAmp and converted from FLAC to FLAC Level 6.
Out of ~2900 FLAC files, there was about a 3GB drop in size in the overall folder (I output everything to a new folder, same folder structure).
(There were also 2 files less in the new folder,
whatever)
Is that realistic, only 3GB reduction in overall filesize?
If so, I might as well just keep doing things as I have and not bother finding those 2 files that got lost or fixing up the little imperfections in the newly converted library.
If not, what did I do wrong? Is there another way to do this? FLAC to WAV first then to FLAC 6?
Thanks for any and all help!
