I've seen lot of my friends running around crazy to get their hands on floorstanders believing that it is the final word for speakers, and then coming back again to bookies. Let me confess, I was one such guy, until I started listening to good bookshelf speakers. Unless you are listening to music in a huge hall, bookshelves are the way to go. Musically bookies are way better than floors. Some say floorstanders have more bass, but most of their bass is unpleasant, if at all they produce any. My suggestion, go for a good bookie.
Guys let me throw my hat in the ring. I firmly belive that small to mid size rooms will work better with book shelf speakers. Though the low frequency extension of a FS will be better, ultimately bass is the most problematic area - acoustics wise - in a small room. You are likely to experience boomy mid bass, extreme nulls and peaks etc. with normal floor stander placement i.e; a few feet away from corners. If you want FS to work with a small/medium room you have to be willing to spend considerable time on placement and ultimately some FS will never work with small rooms. However with BS this problem can be greatly mitigated, and nowadays many larger bookshelf designs have bass xtension to the 40-45hz range below which very few musical instruments venture. Finally if one really want low bass in a small/medium room - assuming they like organ recordings or perhaps a lot of synth bass, a subwoofer will be a better bet as placement flexibility is much higher. Perhaps it may cost more (BS + subwoofer) when compared to FS, but it IMO it sounds a whole lot better expecially at mid and low bass.
Sid
Yes agree 100%, they should be called stand mounters, but book shelf name seems to be persisiting for whatever reason. However my recommendation of a BS over FS for a small room has nothing to do with space saving or footprint but everything to do with mid bass and below frequencies which are very difficult to get right in a small space. And yes I agree one has to factor cost of stands.Most bookshelves however are not really bookshelves.
Personally I do not like to mess with any equalization, atleast for me it degrades SQ, and yes integrating a sub into a stereo setup is not easy as well, (especially if the preamp does not have sub out, even worse using the built in x-over of sub with line level inputs - adds another component in chain - usually not a very good one with lower cost subs - along with another set of interconnects)If bs plus sub requires careful setup or eq, then the same can be said about an fs. An fs with room eq would give us the controlled bass we are harking for.
Good point. But that added cost probably gives much better bass and flexibility on sub placement that is not available with FS.There is one thing to think about in the logic you gave (and many other have also given). Bookshelves, at least most of the compact ones simply do not give any bass. Or they are so inefficient that they require a monster amp to "shine".
Good bass is as important as good midrange or good highs. After all, it is part of the audio spectrum and ironically, with age, we lose our ability to hear highs but don't lose our ability to listen to bass.
If you want to do a true cost benefit analysis, you should compare the sound quality of a floorstander with bookshelves plus subwoofer. Once you include the cost of a sub, you realize that you get much much less quality of speaker for your money.
Otherwise, it is like comparing a decent all rounder TV with another TV that does reds and greens very well, but cannot render blues. Sorry for the bad analogy!![]()
Please do not hijack the thread. Instead open a new one for your separate query.Hi All,
I am new to this Forum, need help I have brand new Jamo 708 Speaker only single Speaker. As I lost one Speaker and Yamaha set in transit. I had planned to use this set of speakers along with my Yamaha 2600.
Now the bloddy set is gone and this single Tower speaker is left.
How can I best utilize this single pc.
I would require a amp (may be a good mono Amp).
Please suggest.
AB
