reubensm
Arab, please refer to this post by our antenna expert, omishra: http://www.hifivision.com/am-fm-tuners-satellite-radio/44076-my-new-used-fm-tuner-2.html#post497695
Thanks everyone for sharing their inputs.
Alright, here it is..
I know you already made a purchase. Here's one by a Indian company and its more than decent.
Tuners | PRODUCT Category | DNM Enterprise
When I initially connected the antenna there was no difference in the sound, I thought the port is not working. Later, there I realized that the noise increased when Antenna is connected, so the port is working.
I have done some reading regarding the antennas and there are 2 types
Yagi - I don't have time and resources for this at this right now.
Dipole - Full Wave Loop and Half Wave Loop
Basically the loops are shorted circuits, am I correct?
I have currently built a half wave loop using aluminum hanger.
But I guess the calculations are wrong and its not yielding any results.
So here is what I picked up form yahoo answers. Antenna length should be 300/F (300 because of the speed of light) in meters.
I will use F=98 as it is in the middle of the band. This will give the length in meters as 3.06m. For a half wave the length would be 1.53m.
I will try this out and let you know the result.
One important thing is, should the wire strictly be a coaxial? Im currently using a speaker wire, that I had bought during school days.
Also, I tried using the antenna provided with my Pioneer AVR, this did not improve or reduce the signal reception. Is this expected?
Do you have any experience on this brand - DNM. Have you seen this tuner in use?
You've got to start with the basics first. Even a mercedes needs a road to run on after all![]()
Tell me one thing, if I remove the antenna pin from the back, will the sound quality/signal reception reduce? What I see is nothing changes in my case, that is where I feel if the antenna pin is really working :sad:
Its working fine, except for one or two channels. I was looking for "CD quality" that was mentioned in one of the posts. I will continue to use it this way, may be I will build the Yagi some time later.
Pardon my ignorance! Yes, I read in some post about CD quality!Well, its alright, not bad after all..
