For prospective buyers of Yamaha RX-V667
As you said its made in Malaysia,so thats it.My onkyo is made in Malaysia & has voltage switch.I purchased it from Sumaria.So not to worry.
Does the model available in India has phono input?
Can someone please tell me the current best price for this model (grey/ with bill)
The backpanel power rating is NOT a max power rating unless it states it. It's typically 2 channels driven at full rated power for 2CH amps/receivers so 140wpc x 2 + say 50 watts for processing / 0.5 eff = 660 watts but for multi channel receivers they typically run 1 channnel at rated power and the others at 1/8th power which is much closer to the 500 watt rating on the backpanel. This is how UL does their heat dissipation tests
My model has the made in Malaysia on it.
Phono, Voltage change, etc
Dont fret, its a genuine product. Mine came in a sealed box.
