Front in-door speaker replaement suggestion
cha_indian
Hyderabad/Chennai, India
Hello,
I recently bought a 2002 Honda city Exi and it had a very good sound system and speakers. It has a Pioneer cassette system and 4 clarion speakers....two at the back are good but the one on the front right door is vibrating. I have replaced the speakers with Pioneer speakers for Rs 900 with absolutely horrible SQ....i feel like kicking my self for buying those speakers.
Then i checked with the Honda showroom and they said they will place an order but since the car is a very old model there is high probability of not finding them. Guys i just want to know if we can find clarion speakers or any equal replacement? any help is highly appreciated.
Thx
What is the size? 4 inch or 6 inch?
You can go for JBL speakers (4 & 6 inches available). It has inbuild tweeter also. SQ is good.
Another best choice is Hertz.
The market for 4" model is not there much. Suggest you to change all 4 speakers. Something like Auditor would cost you around 6K for all four. 4" for the front and 6x9 for the rear.
If you insist on Clarion, then check with Carplus.in as they are the official dealers for Clarion in India
