I just started building my FH3 (Frugal Horn)
Material used : 18mm MDF board
Tools : Manual and carpenter (tried to cut them via CNC but none of the folks ready to do this petty work and I got thoroughly frustrated with their attitude so decided to do myself)
Design:frugel-hornMk3-1v0-250212.pdf (page 7 Sheet FH3.2, Page 9, Sheet FH3.6, Page 17 Sheet C-2)
So far I have managed to cut the individual pieces for both the boxes and the dimensions I got are as below.
1. Internal - 756mm x 140mm - 2 pieces
2. Top - 195mm x 140mm - 2 pieces
3. Baffle - 869mm x 140mm - 2pieces
4. Back - 830mm x 140mm - 2 pieces
5. Bottom - 459mm x 140mm - 2 pieces
5. chokepoint - 18mm x 140mm - 2 pieces
6. Side Panels - 900mm x 459mm x 194mm - 4 pieces
Curve was made using method described in pdf and 4mm plywood by bending it slightly and cutting along the line using circular saw then little sanding..
I am assuming the two 18mm x 140mm pieces are to form the half circle if so, I need help here from FMs who already built this to confirm whether I need 2 more pieces to complete both boxes??) or
It feels like the pictures in the pdf file says the half circle is achieved by half rounding the internal boards then what for these two (18mm x 140mm) are used for??
Now to drill hole for Drivers and then start assembling the boxes.. Any review of the sizes, suggestions, best practices, guidance highly appreciated
Some pics off woodwork so far:
http://i62.tinypic.com/2ecmzxk.jpg
http://i60.tinypic.com/23v1g75.jpg
http://i61.tinypic.com/vx21bn.jpg
http://i58.tinypic.com/2dl2q1u.jpg
http://i61.tinypic.com/20gb6lt.jpg
http://i62.tinypic.com/14j2t1z.jpg
http://i59.tinypic.com/2nvtqa9.jpg
Drivers:
http://i62.tinypic.com/289kmkw.jpg
http://i60.tinypic.com/am84r6.jpg
http://i59.tinypic.com/muzseb.jpg
Drivers:
