General question to maximize the feel of HT
kannan_r
Chennai
Friends,
Normally mp3 size will be 5 mb per song & avi movies will be 700 mb per movie.
Through one of the threads, I realized that mp3 music can output only stereo kind of music even in 5.1 HT.
Also when a downloaded torrent movie with avi extension is played we will not be able to enjoy the benefits of 5.1 HT for audio .
If that is the case,
Q1) what should be the extension of music files and movie files which can utilize the features of HT 5.1 to the core.
Original CD's from stores are bit expensive and practically not possible (atleaset for me) to buy every now and then.
I am sure many members do follow the same footsteps like me and depend on Internet to download and play music & movies for free.
Your replies, will help us to search and focus to download the right movies & songs with appropriate file extension to harvest the maximum benefits of HT setup.
:signthankspin:
Hi Kannan,
i have had this dilemma as well - and found that for video, one needs to look for AC3 files - this file format captures the 5.1 audio features. The filesize is larger and wont fit on a CD, but the SQ is quite good and makes full use of the HT. Hope this helps!
Thanks spirovious,
MP3 can be made 5.1 with DD prologic OR Dts neo settings on AVR.
Mostly I will go for Onkyo 5105 / Onkyo 6200. I hope this setting (DD prologic OR Dts neo) is available in this AVR.
some Music in Dts format is true 5.1.
Also it is not easy to get dts songs from the net very easily unless you really have patience. Size of Dts per song will be approx 50 MB as opposed to 5MB per mp3 song.
Just in case if I convert an mp3 song to dts format using some converter, will it make any difference ?
Thanks unBound,
Hi Kannan,
That's great. Any idea about the size of AC3 file per film.
if I convert an avi movie to AC3 format using some converter, will it make any difference ? Also not sure whether my DVD player through USB port can play AC3 movies.
Typically, upscaling will not produce any significant improvements in the audio part (especially from 2.0 to 5.1) and may not be worth doing it. You could try with 1 or 2 albums and take a call if you want to continue with it.
Songs:
You should look for mp3 songs above 190+ kbps when you are downloading. These mp3 would be of better quality. I would always prefer 320 kbps. The best offcourse is to download Flac version of songs, they are loseless format and retain 100% of the CD quality.
When you play it in Onkyo etc set the surround to Dolby and you will get 5.1 effect.
I understand your point saying cant buy Music CD. WHat I do is, I download the FLAC version or 320 kbps mp3 version. If I really like the songs, I buy the Original Music CDs else I crap it. This way you can avoid blowing your money at the same time support the artist.
Movies:
.avi is just a container. Most of the 700 mb .avi files have stereo. Henceforth, avoid downloading them. Look out for movies with 1.5 mb + which has 5.1 audio in it. There are many torrents like that. Most of the DVD rips are that way. The movies are available in /avi, .mkv, .mp4 etc formats
These movies will give you the best result than a 700mb movie
Thanks unBound,
It wont. Garbage in is always Garbage Out :)
Ensure the source is 5.1. Most of the DVDp wont play AC3
Kannan:
Madbull, Spiro and other have answered some of your technical queries. What I am attempting to do is to give you a basic understanding of music and movie audio formats.
The number of channels in a music or movie score does not depend upon the technology - Dolby, MP3. FLAC, DTS, Neo3 or whatever you may call it. It depends upon two important factors - the number of microphones used during recording, and the number of channels used during mixing and transfer to master tape. All your CDs/DVDs are then cut from the master tape.
Most musical scores are recorded with just two microphones - one for the voice or main instrument, and one for all other instruments. Some advanced studios use multiple microphones - one for voice, one for drums, one for chorus, and even one for each type of instruments. The recordings are sent sent to an engineer, who first cleans each channel of all extraneous noises, and then carefully mixes these channels to create a two channel master tape. Generally what the engineer will try to attempt is to play the main voice or instrument dead centre and surround that with various instruments. Since the assumption is that music is usually played in a stereo system, even background music is played in both channels, albeit with varying degrees of amplitude to give you the off-centre feeling.
Thus, if you take a pure Rebook CD music piece and play it, irrespective of what technologies you use, you are listening to only two channels. What technologies such as Neo3 and others attempt is to play the same two channel audio in all the 5.1 channels, and play around with the frequency and amplitude settings for each channel to give you a feeling of getting surround sound. For example, if I limit the frequency to the right surround channel to be between 5,000Hz-10,000Hz, irrespective of what I am playing on that channel, you will hear only sound between these frequencies.
Movies are a different game. Surprisingly, there is hardly any audio recording done when the movie is being shot. For dialogues to be lip synced by the artists, a loudspeaker will be playing the dialogues or music. The actors will listen to these sounds and either dance or speak their words. Mind you, what the actors speak during the shooting is not recorded, or, even if recorded, is deleted later on. When the film is ready, the actor is called to the studio and asked to speak the same words again watching his or her own lips on a preview screen. This delivery of dialogues is the one that is recorded.
All other sounds such as music, crashes, bird sounds, etc, etc., are all created in the studio. Each of these sound will be completely devoid of any other collateral sound. These could be recorded in any number of independent channels, sometimes running to even 24 channels.
The movie director then sits with the sound engineer and mixes these independent sounds into either 6 (for 5.1) or 8 (for 7.1) channels. Each of these 6 or 8 channels will have completely independent sound and is encoded in one or more ways to specify the timing and channel. In the cinema hall or at home, a Dolby or DTS system will understand these encoding, decode the sound, amplify it, and send it to the appropriate channel for delivery.
Thus, whether you are using a music or movie audio, the closer you are to the way the original recording is done and what the artists or director intended, the more will be you enjoyment.
When you consider music as such, unless you go back to the original recording tapes, and remix them into multiple channels for surround sound format, you are only fooling yourself if you use any software to convert a two channel audio onto 5.1. As I said before, all these software do is to take the two channels, play then on all channels, and use frequency and amplitude variation to give you a surround feeling. Of course, many people enjoy such conversion. BUT, if you listen to a original 5.1 version of the same song recorded in a studio that has the original master tapes, then you will understand the difference.
Please do not be under the assumption that a file extension can magically change your audio. It cannot.
