Grand i10 | Connecting aftermarket speakers to HU directly without amplifier
swift
India
Hi all,
Looking for expert suggestion on my query below.
I would like to replace OEM speakers in my grand i10 with Morel or Helix speakers. Is this fine without burning speakers or Headunit?
I understand that the putput wont be that loud without the amp but i am specifically concerned since the RMS of OEM head unit is around just 1/4th of the speakers.
Without knowing the specs it's hard to recommend but you don't need to add an amp.
The car HU comes with a built in amp that should be able to drive most speakers.
Can you share some more info on the HU and speakers that you plan to install?
Planning for either of the Speakers listed below:
Option 1: Morel sensus 63-3 way-120 watts RMS
Option 2: Helix S 62C -2 way-100 watts RMS
Car: grand i10 diesel 2014 model.
Headunit is factory provided , unsure of its RMS value. I assume, as a standard, it could be anywhere between 25 to 30 RMS
