Grant Fidelity Tube DAC 09
deepakgang
Dear Friends,
Does anyone have any experience with this DAC? I have read some good things about this but couldn't find any in our forum. I was planning for a budget DAC and had almost finalized Musical Fidelity VDAC or Beresford 7250 when I read something about this ..
This looks like one of those Chinese product that is re-badged by various sellers. I was concerned about the low SNR as well as the limitation of 96kHz in sampling.
Chinese but looks like worth trying and doing a comparison with a budget DAC ! .. Maybe try with changing the tube with a better one
Its a good DAC, if you have a chance do try it. You can tube roll if needed. Do not worry too much about SNR figures, this is more often than not just a direct conversion of the number of bits the DAC chip works at, it has nothing to do with the real SNR of the entire unit.
cheers
