Great deal from Newegg for ReadyNas
Yes Anant, it can run Squeezeserver.
For Borderlinx, you just need a Citibank Credit Card to start off. Getting a Citibank Card is easy if you already don't have one.
yes, I meant I do not have a citiback CC. Few months back, I was offered @ shoppers' stop for co-branded card, and I jumped on the opportunity. It got rejected as I did not have ANY other credit card at that moment.
Thanks GeorgeO for sharing this.
The pricing is good but it says "speeds up to 25MBps" which is less (possibly limited by the slow network processor which reflects on the cost as well). However, it should not really be a concern unless you plan to stream BluRay ISO's. Audio streaming and Bluray rips should run fine.
