Harman kardon avr 4000 is not working :(
smnrock
blr
Hi there,
My friend having above mentioned avr which is not working now, its getting power on, but sounds are not coming. Earlier the sounds will come after 20-30 mins from when its switched on, now thats also not working. We are in bangalore and any help appreciated for making to work :P. Thanks
Hi there,
Search on forum as a number of issues on AVR and possible resolutions are provided. For starters, disconnect everythng and see if the AVR stays on and then start connecting one component at a time and finally one speaker at a time to figure out if others are causing it to shut off.
have you purchased locally? Try contacting the dealer who sold it to you.
No, it was purchased from dubai :(
Component means, one input source? And we tried connecting one speaker at a time and the result is same. Earlier he gave to some service center(?) and they kept it for a month, then returned saying it cant be repaired here :(.
Any good service center here in bangalore?
contact ::: JBL ::: and they have a bangalore dealership i think. JBL / Harman Kardon are from the same stable and they might be able to help you.
mpw
