H Hari655 Active Member Joined Oct 2, 2012 Messages 101 Points 28 Location Hyderabad Feb 20, 2013 #1 Egreat S7A
K kaptan Active Member Joined Jun 6, 2011 Messages 651 Points 43 Location chennai Feb 23, 2013 #2 There is no media player with analog output as far as i know. If you want to spend such amount better go for Dune HD Max which comes with a bluray player aswell.
H Hari655 Active Member Joined Oct 2, 2012 Messages 101 Points 28 Location Hyderabad Apr 19, 2013 #3 kaptan said: There is no media player with analog output as far as i know. If you want to spend such amount better go for Dune HD Max which comes with a bluray player aswell. Click to expand... Hi ...i settled for HTPC i upgraded by old pc its working perfectly well. Upgrade includes: 512 MB RAM to 2 GB - 1500 Rs. 1 GB Graphic card - 1600 Rs. 5.1 Sound card - 450 Rs. Thanks, hari
baijuxavior Well-Known Member Joined Mar 7, 2011 Messages 4,393 Points 113 Location Kerala Apr 19, 2013 #4 That is a smart decision. Which media player are you using? If it is a dedicated htpc then use XBMC.
P prosenjit New Member Joined Jun 30, 2012 Messages 2,393 Points 0 Location india,kolkata Apr 23, 2013 #5 Hari655 said: Hi ...i settled for HTPC i upgraded by old pc its working perfectly well. Upgrade includes: 512 MB RAM to 2 GB - 1500 Rs. 1 GB Graphic card - 1600 Rs. 5.1 Sound card - 450 Rs. Thanks, hari Click to expand... hi hari...can you pls share..all specs..old system and new system...?? not every detaill..just model.. like processor--intel core 2 duo thanks
bpranay Active Member Joined Oct 22, 2012 Messages 504 Points 43 Location Chandigarh Apr 23, 2013 #6 Egreat S7A Somehow this website shares great resemblance with hifimart.com is it owned by the same person?
baijuxavior Well-Known Member Joined Mar 7, 2011 Messages 4,393 Points 113 Location Kerala Apr 23, 2013 #7 ^^ I don't think so. These websites use a common design. detna.com, theitwares.com etc use similar design.
H Hari655 Active Member Joined Oct 2, 2012 Messages 101 Points 28 Location Hyderabad May 22, 2013 #8 prosenjit said: hi hari...can you pls share..all specs..old system and new system...?? not every detaill..just model.. like processor--intel core 2 duo thanks Click to expand... Hello Sir.. Sorry for the late response.. my old pc: Core 2 duo, P4 Thanks, Yashwanth
