HDMI CABLE Chennai
prithivi
chennai
Hello friends
i want to buy a hdmi cable for connecting my lappy and tv
using it only for video purpose
Budget Rs 1000
can extend my budget if needed
THANKS
N.K.V.Prithivi Raj
I dont claim to be an authority on the quality of HDMI cables but from my own little research which I did when I had to buy 1 I found out that they are mostly the same and there is no much difference between the cheap ones and most expensive ones.
I got 1 such from EBAY for around 400-450 Rs. Including the shipping and it works fine. I dont know if any other would have worked better or not.
You can check ebay to find a good variety and maybe you will find 1 which you want.
I got a dynex HDMI chord from ebay for 260 bucks. Use it to connect my plasma to laptop. Works fine. I got a 100 bucks off, from an ebay coupon.
ok ok thank you friends can any one refer me local sellers
bec as i am goin out of station need it today
You can get decent quality HDMI cables from MX in Ritchie St, off Mount Road. Try at Vinsun Agencies. If you spend a little more you can get Daiyo cables for around Rs. 1500. Mx price varies from 600 - 800
Regds / Shailender
Hello friends
Budget Rs 1000
THANKS
N.K.V.Prithivi Raj
Hi Prithivi Raj,
As you are in Chennai, you can try MX HDMI cables. I haven't used it but in general MX products are VFM products. I am using their interconnects for my stereo setup. Please refer the following link:
MDR Electronics - MX Electronics - Home Theater Cables & Connectors - Computers & Laptop Accessories - Pro Audio / Studio Audio Cables & Connectors - Audio Video Components & Accessories - Fiber Optic Component & Accessories - Cable TV Component & Ac
You can get the cables for lesser price than mentioned in the website. Here are the contact details.
VINSUN AGENCIES
3-B, Wallers Road, Anna Salai
Region : Wallers Road
Country : India
State : Tamil Nadu
City : Chennai
Pin : 600 002
Email : [email protected]
You can also try Mercy Electronics (they have stores in Adyar - LB Road just before the telephone exchange when going from Adyar side) or any other small electronics shop. U should be able to get some Taiwanese cables for around 400 bucks. I bought one at a small shop on OMR for 375 bucks and this is what I use to connect my WDTV HD Media Player to the LG 42PQ70 plasma. Works fine and quite happy with the picture quality too.
