HDMI in whole home connections.
levitate
Now that HDTV is mature , more home will likely use multiple HDTV.
For best quality, you should transport digital video and audio over HDMI.
This HDMI matrix switch will enable you to integrate all your HD sources and distribute them to 4 HDTV.
Another unique way to connect your HDMI over long distance or over the entire home, is to use HDMI over Ethernet Extender which allows you to carry HD 1080 over HDMI on CAT 6 cables.
CAT 6 cables are readily available and are easy to terminate on site.
