Headphone cables for Focal Clear Mg
essrand
Goa
Normally I would not go down this rabbit hole but the TRS cables with my headphones are really short (on the other head Focal gives really long balanced cables but my DAC doesn't have a balanced output for headphones).
Any suggestions on what cable to get?
Budget is flexible but would like to keep it under 35k which is the absolutely upper end, but basically prefer the cheapest option that would be the equivalent or beat the headphone stock cable.
Typically I just blindly buy acoustic revive cables but strangely their headphone cables do not have a TRS to trs wires.
If you are ok with getting custom cables made reach out to Niranjan Nande , pm'ed you his contact. He makes silver/copper cable with terminations of choice.
