Heatsink innovation
Do you guys cover your avr while not in use. Like cloth cover over the vent holes array.
Yes. I cover my speakers+sw, receiver, media player and TV while those are not in use. I use the cloths which are used for curtains. Not too thin, not too thick. Helps to block most of the dirt. Since receiver has a lot of vents, I use a towel over and above the cloth since my room has a lot of windows.
But I make sure that I never cover my equipments right after using as they are hot then.
