Tiwana
hello,
i am looking to buy 5.1 speakers for gaming only. I have narrowed down my selection to f&d f5090. But here i have run into a problem as i have zero knowledge of RCA jacks given in the specifications description page of the product.(F&D F5090 | 5.1 Home Theater Speakers | Multimedia Speakers )
I previously owned creative 4.1 speakers. They had 3.5mm jacks connectivity cable which went into the subwoofer & in onboard audio jacks.
My FIRST question is will i be able to connect these speakers with my current onboard jacks ( http://i.picpar.com/WPfb.jpg ) with the connectivity wires which come with this speaker system? or will i have to buy some converter !!! The RCA jacks confused my mind
I am going to purchase a sound card which supports dolby digital in a month or two in range of 2k to 5k. So my SECOND question is will these speakers give 5.1 dolby digital or DTS sound with the sound card as in the description page of the product connectivity option is given as stereo audio ( RCA jacks).
MY 3rd question is what equipment do i need for 5.1 dolby digital & dts audio? As far as i know i only need 5.1 speaker & dolby digital supporting sound card. OR something else is also required
Please suggest some other speakers if they will not support 5.1 dd or dts with sound card under 12k & also sound card under 5k. i have total budget of 17k.
Gonna use the speakers only for gaming only , headphones for movies & do not listen to music
