Help in buying TV
nithin
TRIVANDRUM
Help me out,
I am looking to buy an 32" LCD/LED TV with a budget around 22-25k(lower the better), should be able to play movies(most formats) through USB and planning to take Videocon D2H(HD) along with it
Can u guys suggest some models?
And will HD ready models be able to play 1080p movies through USB(if so suggest some models that does)?
Also heard some videocon tv models have inbuilt D2H support,is it true?
Suggest Philips one with DDB, considering that you are looking at a low budget TV.. You can directly use your videocon DTH into it..
Yes Videocon TV has that feature.. But I think Philips is way better.. and the price difference should not be much
