renjith lal
Hi All,
Need help in buying carpet for my living room which I use for music and movie. Of late I realized the importance of good absorption material and room treatment
. As a first step I though of putting a good rug.I am attaching picture of my setup for better understanding.
My setup is in living room and I have all type of issues. Lot of reflections from tile, french window etc.So I need help in buying a good carpet. I already have one typical carpet generally we use. I feel a good rug will absorb lot of sound/reflections and it will help in improving sound quality. I am also planning to put some absorption panel/ foam pad in front of french window.
Can you guys suggest some good carpet (brands or what material I should buy) so that I can buy it. I can see lot of options but I just want to buy a good one and not end up buying a bad one for sound absorption. Please let me know your experienced suggestions.
Any suggestions other than rug is also appreciated.
Thanks in advance
Renjith
Thanks in advance
Renjith
