Help Needed With Pioneer N50
Scuba Collie
Uk
I have the Pioneer N50 which streams MP3 fine over LAN but not FLAC? I have another media streamer (the Mede8er) which streams FLAC over LAN perfectly from the same PC??
The Pioneer wont even attempt to play it, had an 'i' next to each of the FLAC tracks?
Can anybody help me please?
Many Thanks
What's your source?
Not all AVRs, receivers will decode FLAC, in which case it becomes necessary the source decodes the FLAC files and sends it as PCM stream.
Or it could only support FLAC files up to a certain resolution.
Check the specs of the Pioneer and also the FLAC files.
