Help needed!!!!
aneelr
bangalore
I encountered a strange problem.
I'm using my WD HDTV media player with my samsung 46" LED TV via a HDMI cabel......and it was functioning well, till today....when I downloaded this demo, Sony Blu::Elements- Forsenses (2009)DEMO Blu-ray and started it to play the same, it started of fine but inbetween it stoped and my TV is giving an error that HDMI mode not supported........
Is it the problem with
my LED TV,
my HDMI cabel,
my WD HDTV media player.
please help needed!!!....
thanks.
Are you trying to play HD Audio? If so you should be HDMI 1.3 compliant
my LED TV,
my HDMI cabel,
thanks.
hi,
after doing some r&d i found out that it's the problem with my downloaded file, it is not been properly extracted frm the BluRay disc.....
Now everything is back to normal.
thanks marsilians for ur reply.
