Help!!! Purchasing of reciever frm USA
harsha.chelikani
Hyderabad
Hello im a newbie and was wondering will a denon 3310ci reciver available in USA work in india...have a doubt due to the region code present there is ntsc and here is pal and how should one address the voltage issue...thanks in advance for help
No worry about the region code or Pal/NTSC issues for an receiver. Only worry about the voltage. A decent converter will solve issue, but better to buy here if your savings is not less than 50%.
do you have any idea about the ritchie street market in chennai..can i get a source a good reciever there...
It is best to avoid buying stuff from here.
Most items are second hand/discarded stuff from Singapore,which are refurbished /repaired by the several"technicians" who have shops in and around Ritchie St.
It is possible to pick up a good used item that hasn't been worked on by a "technician" but the odds are against it.
Rajiv
