S Saikrishna2 New Member Joined Feb 5, 2021 Messages 4 Points 1 Location Vijayawada Jul 25, 2021 #1 Hi I am moving to Canada. I am using exposure 2010s2 amp and 2010 dac. I want to know can we use step up transformer for this setup which wattage step up up transformer should we use.
IndianEars Well-Known Member Joined May 18, 2008 Messages 1,393 Points 113 Location Mumbai Jul 25, 2021 #2 The wattage of each product will be mentioned on the product... usually on the rear panel close to the power socket / cable. Take the sum of wattages of each product, add 10% for good measure and that will be adequate rating for the transformer.
S surfatwork Well-Known Member Joined Aug 7, 2007 Messages 487 Points 63 Location Kochi Jul 26, 2021 #3 But why do you want to lug it there? Sell it in India for a good sum - you'll.likely get enough to buy a new one there.
