Help with new 3D projector
prashanth_brp
Chennai
Hello,
I am living in Chennai. I planned to buy a 3D projector for home. After searching a lot on internet I got confused which one to buy. Please suggest the models available and price also.
My budget limit is 50,000 - 55,000 INR
My requirements are,
3D - 3D Ready
Projection System - DLP
Native Resolution - Minimum 1024 x 768
Brightness - Minimum 2500 ANSI lumens
Contrast Ratio - 10000:1 and above
Image Size - Minimum 200
Lamp Life - Minimum 4500 Hours
Resolution Support - VGA(640 x 480) to UXGA(1600 x 1200)
Interfaces - HDMI 1.4a, VGA,
Special Features (Optional) - USB plug and play, Wireless display,USB
Hello,
3D - 3D Ready
Get acer h5370 or h5380bd from amazon it will be under 35k but no warranty. But the features they deliver eill match all requirements.There is a separate thread gor this acer model.read it.if ur keen on warranty go for epson tw550 may be around 60k.good luck.
What are the advantages of Acer h5370 over Benq W750?.
Get BenQ 1070 if you are going import route. Full 1080p with amazing 3D.
