Help with setting up an Optoma HD25e
Well, I found two good options. One is a 1100VA normal APC UPS. The other is a 850 VA Sine Wave UPS by APC meant for household electronics.
I'm assuming the second one is recommended?
Edit: Turns out the second one is a full inverter which will need a massive battery - which I don't have space for. I called APC and the guy was saying a 600 VA will be fine (I'm assuming he's wrong)... Shall I just get the 1kva by APC?
Please take good care about the air conditioning for the entire setup because the lamp life depends on cool air circulation. Don't compromise in this aspect. if you think about money you will lose the life of the lamp.
