Home theatre Speakers
sriram2300
Germany
Hey All,
Its me again. I have an Onkyo Tx-sr 508 receiver, so could some one suggest me some good speakers package for 30k. I will be using this for both my movies and music. So considering that can you guyz please suggest some good 5.1 packages. It would be great if you guyz can suggest me some place in Bangalore.
Sriram
Onkyo got SKS-HT728, which is around 36k.
If you can spend more, Polk Audio TSi models can be considered.
Polk RTi series is also very good but price is high
hi guys,
i am new to this forum.
i have purchased denon 891 from USA for Rs22000. Now i m looking up for good quality floor standing speaker and center speaker. I am willing to spend abt 80k. thanks
hi guys,
You should look at Polk Audio or if you can afford it go for KEF.
@OP:
Try the Boston Acoustics CS2310, paradigm ct 70. You can also try out the following combination from polk if you can go over a little. TSI100, OWM5, PSW 110/some other sub like sw150 should cost between 35-40k.
hi guys,
Try out the Aviano s that haisaikat in this forum has bought. search for his thread and you will get the prices.
I think he got Aviano 6 (front) aviano 2(rear) aviano 5 (center) and aviano 7 (sub).
Or else you can look at wharfedales, 10.3, 10.1, 10.0cs and sw150 for front, rear, center and sub resp. Should come below 80k.
Also, it is good to make your own thread. Thats courteous to the OP. no offense meant :)
Edit: just noticed you had made a thread.. apologies :)
