how to clean my screen?
manu4panjab
in my house..,
hey bros.
how to clean projector screen
my screen now shows some dirt spots by they won't remove with simple cloth so any suggestions
i'm scared of using any detergents as it will remove special coat on the screen
hey bros.
Absolutely no detergents.
1. Use a dry microfiber cleaning cloth to dust out the screen
2. Use a spray bottle or damp a second piece fo microfiber cloth and clean from one side to the ohter - (Left to right or vice versa) and top to bottom
3. Take a third piece of microfiber cloth to dry out the screen.
The screen should be cleaned once a week due to the dust buildup.
These cloths can be machine washed and re-used.
thanks for your reply brother
mmm as you said spray bottle is it just plain water or what in it
and where to buy this microfiber cloth
Microfibre cloth by 3m is available in malls & supermarkets on 3m stalls...
too good to wipe screens,sunglasses,laptop screens,mobile screens etc..
some ppl find it pricy but too good
Manu, i know of a imported cleaning kit which is available but then that is not for fabric based screen, it is for screens like lcd tv, or the fibre based screen which i have. The kit consists of spray, cloth and a brush.
Vinay.
Vinay.
thanks bro
but i have fabric bases screen i guess
