prakhardeep
Okay, here is what i have:
Speakers: Logitech 2.1 which only have 3.5mm jack for audio input
TV: LG which has only Digital optical out for audio.
AV: Yamaha V373 :yahoo:
Now, i want to listen my TV audio on the 2.1. What should i do ?
Can i do this:
Process1:
1. Connect the TV optical out to optical audio IN of AV
2. Get a stereo RCA Male to 3.5mm female jack and connect it to Audio output of AV
3. Plug in the 2.1 into the above 3.5mm female.
Process 2:
Or, i can also simply plug the 2.1 into headphones jack of AV instead of step 2&3
What would be different if i do the process 1 or process 2.
I was reading the AV manual and it says connect ONLY recording devices to Audio OUT, what does that mean ? I cannot connect my speakers to Audio out from AV ?
Can i do this:
Process1:
Process 2:
