Thad E Ginathom
)my added bold.Folks, READ the question. He wants to know how to identify which pin in a two pin POWER CORD is meant for phase.
Neither is.
if it mattered the manufacturer would have fitted a three-pin plug.
But the question is when you have 2 pin plug without any '+' or '-' marking and when left profile and right profile of that 2pin plug look exactly same, how will you identify the pin meant for phase(+) ?Normally the right pin on the Appliances is Phase. I don't think any Audio device will have any other arrangement. So just trace the pins and your can tag them accordingly.
Sent from my MI MAX using Tapatalk
I checked yesterday with a multimeter, to my horror I found that there is 70 Volts between the Neutral and Ground pins on the wall socket.
Like I wrote, we need to trace using hand as usually the cable is flat and we have to trace the right end of it to connect to the right (phase) on the socket (most electricians also ignore that right side should be the phase so please confirm the same for your socket.But the question is when you have 2 pin plug without any '+' or '-' marking and when left profile and right profile of that 2pin plug look exactly same, how will you identify the pin meant for phase(+) ?
The Right side when one is facing the front of the equipment in question or the Right side when one is facing the back of the equipment?Like I wrote, we need to trace using hand as usually the cable is flat and we have to trace the right end of it to connect to the right (phase) on the socket (most electricians also ignore that right side should be the phase so please confirm the same for your socket.
Facing backThe Right side when one is facing the front of the equipment in question or the Right side when one is facing the back of the equipment?![]()
Absolutely buddy. Some switches control Neutral supply and hence socket and connected equipment will still have Live supply even when cut off! Dangerous!!Perhaps people should check all their sockets then. It is very important that they are wired correctly. Otherwise, a piece of equipment with its own switch at "off" will not be functioning (also known as not "on") but will be live.
An hour or two with a mains-tester screwdriver could save lives. (or cost them --- if people don't know where to stick it!)
