I have already bought the TSi 400 (Floorstanders) and the CS-10 (Center Channel) and an Onkyo 616 (which I'm awaiting shipment from the UAE). I have zeroed in on the rears - TSi 100 - which I'll be buying later this month.
The way I see it, there are the following considerations to make while pairing Center/ Rears with a particular set of floorstanders / receiver.
1) Wattage - Ensure that the receiver can drive the speakers without getting overloaded. To this end I've ensured that the Onkyo 616's max-wattage per channel is more than the TSi 400's max. wattage.
2) Timbre Matching - All Polks are Timbre Matched
3) Relative size of speakers to ensure that they dont overshadow each other. To this end, the decision was easy because the CS-10 and the TSi 100s use the same 5 1/4" drivers as the TSi 400s.
Now I want some advice on how to choose a subwoofer. I have two choices here: PSW 110 and PSW 125 from Polk.
1) Wattage - All Receivers only talk about wattage for the 7 channels, never for a Subwoofer. Since the subwoofer is to be an active subwoofer, is the subwoofer limited by the wattage of the Receiver? For eg. if I buy a 300W subwoofer, will it try to pull the 300W from the receiver, or will it pull them directly from the electrical power supplied to it? If the second case is true, then I should be able to attach a 300 (or whatever) wattage subwoofer with a lower powered Receiver; unlike speakers which would overload and clip the receiver. Is my understanding correct?
2) Can anybody tell me if a 300W PSW 125 will overshadow the max. 200W wattage TSi 400 fronts?
3) I'm assuming for Subs, timbre matching wouldnt be a major issue. Any other Sub I can look at - budget of 15 - 20K Max.
