how to remove grills from speakers
arnprasad
Vijayangar, Bangalore
Hi..I just bought the Polk Audio CS10 center speaker and want to remove its grills. I tried it with my nails and did nt work..nor is there any hint of screws or any other type of joinings that i can unscrew or pull...any suggestions pls? Thx
Its has six connecting points & you have to pull them slowly one by one(not total at a time).Make them loose & slowly pull.
Removing the grills from speakers should be easier than removing the gills from fish. Try prising them little by little with a butter knife from each corner and along the edges. Else carry your speakers to the local fishmonger ... :rolleyes:
--G
