How to setup..
How do you connect your Laptop to your dac?
First of all whatever input connection you use (USB, Coax, Optical), you can try different cables
On the laptop front, optimizing your OS for audio will have a great impact on the sound. It will feel like its a headache and too much trouble, but the result is absolutely worth it. Been there, done that
Try a trial version of Roon or Jplay Femto for audio playback. These software are paid but you can use trial version to evaluate if paying the money is worth
Lastly you can try the dedicated Audio transports like Allo Usbridge , digione or the digione signature
Audio transports....I need to know more about it ...it will be better then a pc setup .right ?..
How much it would cost for setting up??
Rather then cost you will need to be sure if you can manage it
It's not just plug and play but it's perifrmi also is extremely good for price
Search for allo usbridge and allo digione
Should get lots of content to read and understand
