G gowmara Member Joined Sep 2, 2017 Messages 82 Points 18 Location Coimbatore Dec 19, 2018 #1 I have QED reference xt 40 speaker cable and QED screwloc banana plug. How to solder it. Thickness of cable is high.
tuff Well-Known Member Joined Oct 26, 2014 Messages 1,862 Points 113 Location Thane Dec 19, 2018 #2 [email protected] said: I have QED reference xt 40 speaker cable and QED screwloc banana plug. How to solder it. Thickness of cable is high. Click to expand... No need to solder.
G gowmara Member Joined Sep 2, 2017 Messages 82 Points 18 Location Coimbatore Dec 19, 2018 #3 I have qed screwloc banana plug 4mm, however wire thickness is high. It not fitting inside plug. The video is posted is not qed screwloc
tuff Well-Known Member Joined Oct 26, 2014 Messages 1,862 Points 113 Location Thane Dec 19, 2018 #4 It says on the video package and he/ she has a 4mm cable screwed into it. There are screws in the plugs to hold it down.
S sunder Active Member Joined Aug 12, 2009 Messages 712 Points 43 Location india Dec 19, 2018 #5 [email protected] said: I have qed screwloc banana plug 4mm, however wire thickness is high. It not fitting inside plug. The video is posted is not qed screwloc Click to expand... You can try by trim few strands as to reduce the size as to fit into the plug.
jls001 Well-Known Member Joined Feb 9, 2010 Messages 6,182 Points 113 Location Mumbai Dec 19, 2018 #6 Speaker cables are usually not soldered to lugs, they're usually screwed. Cut off some strands as suggested by Sunder.
G gowmara Member Joined Sep 2, 2017 Messages 82 Points 18 Location Coimbatore Dec 19, 2018 #7 Thanks all , will try
N newlash09 Well-Known Member Joined Dec 17, 2014 Messages 974 Points 113 Location hyderabad Dec 22, 2018 #8 Hi gowtham..connecting your bare wire to the speakers binding posts, is the best connection possible. Unless you face a scenario, where you often connect and disconnect cables, dont bother with banana plugs and spades otherwise.
