How to upgrade my existing Stereo System
kingfisher
Tirupati
I have mission QX2 MK2 powered by Marantz 6004 amp. Also use Modi 2 Uber DAC. Now willing to upgrade the setup to improve the sound quality. Now I am planning to buy Marantz 6007 which has built in DAC so that I can eliminate DAC from the chain. My doubt is whether this will significantly improve the sound quality? I have Wiim mini streamer too.
I don't think you will gian any significant benefits moving from PM6004 to 6007 either in the dac or amplification wise.
Its best to move significantly up the chain to say an Audiolab 6000a or the likes to get a significant upgrade in the amplification quality.
Thanks. But Audiolab 6000a is out of my budget. will consider if used one is available.
