IEMs vs Open back headphone sound observations confusing
nmurthyk
Hyderabad
Hi guys, I recently had an attempt to move from HiFi system with speakers to Headphones to get rid of the room acoustics and speaker placement issues to enjoy the music. I am not able to maintain them due to my 2 year old kid constanly moving them and playing with them. My current setup is: Squeezebod touch/Laptop/ChromeCast Audio -> Beresford Cayman DAC -> Marantz 7001 AMP -> QUAD 11L2 speakers. This can give you my taste and reference. I use FLAC files and 320kbps audio files and also use Spotify to listen mostly Indian film music and Indian classic.
As I learned from reviews that the Open back headphones gives best sound stage, imaging and presentation, I purchased Sennheiser HD 599 to use it with my mobile (1plus7) and my laptop. I listened to it for few days and did some burn-in by playing music during whole night. even after around 40 hrs of burn-in it did not impress me. my observation with it is, the sound stage is more of around my head but top to sides, rather than front to sides. imaging is good. there is space between instruments. I liked the tonal quality and smoothness of sound. however did not like the sound stage as I did not feel the soundstage and presentation differrence is huge compared to cheaper headphones(plantations 5220) (or iem (Skullcandy Ink'd plus).
So I have returned it.
Meanwhile I have got an IEM - "Sennheiser Momentum free (renewed)" on Amazon in discount sale as an temporary one. Surprisingly I found it's sound stage is much better than HD599. it is more of 'front to sides around my head' than 'top to sides around my head' I heard on HD599.
Sennheiser HD599 - Priced 20999 - Top to sides sound stage, good resolution, tonal quality, bass, space between instruments.
Sennheiser Momentum Free Special edition - Max price 14,990 - Front to sides sound stage, good resolution, above average tonal quality, low bass, slightly lesser space between instruments compared to Sennheiser. Presentation is also very good.
The source is same for both (1Plus7 mobile)
What confuses me is the open back headphone should have better Sound stage, clarity and presentation compared to the IEMs at similar price range. However I see it reverse. Did I get a defective one in case of HD599? or does it need more brun-in to open up really? or is it something else that I am missing?.
I want to understand this and set my expectations and decisions accordingly as I am looking to buy a good headphone/IEMs to enjoy music without the hassle of room/speaker positioning.
Not all phones provide enough power to headphones. Did you try connecting them to your Marantz amp and listen?
Also, they might need some burn-in time before they start sounding better.
Open back headphones certainly do give a better soundstage than closed back headphones. IEMs are again a different presentation and can give the notion of a better sound stage.
Different headphones have different levels of depth and width soundstage, personally i have found Sennheisers to have a very narrow soundstage (viz HD598/HD6XX) and not a big fan of their headphones currently. Amongst the headphones i have owned i found the largest soundstage in AD700 (difficult to find now) followed by Ananda.
If you are willing to experiment and spend a little go for the AKG K712 and a desktop amp , the AKG712 are supposed to have a wide soundstage and amazing detailing/seperation. Another option would be the Hifiman Sundara , which again has good detailing but the soundstage is not as wide you can expect from an open back. On the contrary Ananda and Arya (the next in line of Sundara's) have amazing soundstage depth and width with the Ananda being slightly brighter and Arya being the more neutral/slightly laidback but a godly level of detailing and seperation.
I tried connecting to Marantz amp and Beresford DAC as well.
So, do you think the IEMs also give a (perceived) better sound stage?
I am not in a position to try many things as it costs a lot. I can certainly try any one thing at around 25k-30k but only once. And unfortunately Amazon return policy not applied for all items and particularly for some of these headphones/IEMs so I wont be able to return them if they are not satisfactory.
Between headphones (ex: AKG712, HiFiMan Sundara) and IEM (Shure se425 or other) what do you suggest for sound stage, imaging and clarity.
Yes top tier iems like CA Solaris , CA andromeda, Z1R have amazing soundstage and the mid range chifi IEMs can almost replicate the same. For me the order of preference is Speaker-> Headphone -> IEMs. I would suggest you to go for Open back HP if below holds true for your scenario
i) You are ok with sitting and listening to music . These headphones are difficult to wear while lying down on bed
ii) Leaked sound is not a major issue to your family members.
iii) Willing to invest in dedicated amp/ decamp in future
While point iii holds true for IEMs as well but they still sound decent out of a phone directly whereas most of the headphones are not easy to drive.
I would suggest you to go for a Sundara for now and later get a budget DACAMP like IFI Hip DAC/ Xduoo xd-05 so forth for about 10-15k , these would most certainly sound amazing. The AkG K712 are very hard to drive and would need a dedicated desktop amp whereas Sundara would do just fine with above suggested portable dacamps
Oh, you needed to power them with a proper headphone amp before giving up. Also check if the headphone outlet in your receiver has enough power.
Honestly i dont think the HD 599 need a lot of power , HD 598 was my first pair of headphones beyond 10k back in the days ( not the SE the normal one with velvet pads) and i was far from impressed with it. I tried it with few amps and Xonar DX / Xonar Essence STX but did not like the overall signature at all. Purchased the 598 SE after a few years but still did not like it .
Probably the series doesn’t match up with your sound preference then. It happens. Hope you find something that does.
Possibly so but the 598 doesnt have a lot of details either for the price they command , the AD700X/ Beyerdyanmic DT770/ AKG K series/Philips SHP9500 seem to give a better performance at a similar price point.
Personally i have found my match with Hifiman planars :)
i) I can but I get very less time to sit and listen to music these days. probably for next 3-4 years. However I can make some time occassionally to truly and consciously enjoy the music.
ii) Leaked sound not an issue for me at all. in fact HD599's sound leakage was very low for me unless everyone is sleeping while I listen to music. even then my wife did not complain.
iii) I would like to avoid investing for dedicated amp as much as possible.
The HD599 leak very little sound, the Sundara's would probably leak a lot more in comparison. Its not an issue unless you have someone sleeping in the room you listen music to. I owned a Campfire Andromeda in the past which I sold due to below reasons
i) After getting speakers i was rarely listening to them. Bedtime listens would be of very short duration not warranting an expensive IEM
ii) If i used it during the normal day, everyone had to stay infront of my face to get me to notice them when they call out to me
iii) Soundstage though very wide was nowhere near the experience I got on my headphones/speakers
If you feel the above issues doesnt apply to you then you can further read about Etymotic ER2XR/Obravo Cupid/Ikko OH10 (Ikko needs to be imported) at a budget of about 15-20k. These will run fine out of a phone as well but will scale very well with a portable dac/amp. Incase you decide for headphones options would be Meze 99C (Fun sounding Closed backs and dont need an amp), Beyerdynamic DT770/DT990 (definitely need an amp ), Hifiman Sundara (Amp recommended to get the best), HE400i( cheaper cousins of Sundara and will do good with an amp).
Would suggest you to invest in a portable DAC/AMP (at the range of 15k), some options being the Ifi HIP Dac/Xduoo XD-05 Plus/Fiio Q5(Used) to get better dynamics.
Based on my preferences i would suggest Hifiman Sundara if you are going for HP and Obravo Cupid/Ikko OH10 if an IEM
I too have the above challenge but with IEM I can use them during morning walk.
I would like to try these IEMs and see if they satisfy me. In the long run it looks like Hifiman Sundara may be a match for me. I will keep looking for deals on these.
Thanks for the advice.
Thanks for your input.
I too am looking to get a HP as I have got a decent IEM which should do for sometime.
I already have the Hip DAC so Sundara was my choice.
However I saw a review where someone said that Deva wired with a DAC will sound as good as Sundara. Do you reckon it's worth that extra money for Sundara?
Keep an eye on the Amazon Sale from 17th.
They have Hifiman stock.
I have not listened to Deva , but have had a good listen to the Sundara, Ananda & Arya. There is a fair amount of increment as you move up the chain , the Sundara are very revealing and are slightly bright with a decent soundstage (not the widest i have heard for a openback but better than HD6XX ) . Ananda has a very engaging forward presentation with a slight treble spike with a very good soundstage which usually goes unnoticed except in older recordings. Arya I found to be much more laidback and with amazing details across the spectrum and soundstage was the best amongst headphones i have heard till date, there is supposed to be a treble spike as per the reviews but i did not notice it for songs i listened to.
I feel Sundara would have finer subtleties which the Deva would not have , but cant be sure unless I listen to one. But Sundara are well worth the price tag and do justice to all kinds of music maybe other than music which have lot of emphasis on vocals.
Thanks a lot for your feedback on this.
Will ignore the Deva and consider the Sundara unless I find something with a better sound stage in that price point.
As I read..your input confirms what Arya is advertised as.
Phew...that price.
The price for Arya is one factor, the price for making it sing is a different ballgame :)
I had the Arya on a loaner tour for almost 2 weeks and had a demo unit of Ananda for around 3-4 days , my SS amp did not synergize really well with the Arya in terms of the tonality but the details were more than present as compared to the Ananda which were singing quiet well but i could notice the layering of instruments was not as good compared to the Arya. Was not in a position to invest in a new amp setup and decided to go for Ananda.
Still interested in going for an Arya some fine day with a tube amp, but for now the Ananda is more than serving its purpose.
