Importing TV from China
TBon
Hyd
Hello all,
I getting a container from China and was wondering if it makes sense for me to purchase TVs and other AV products and get them in the container. I am not sure how these are priced in China compared to India.
Thanks,
Moh
Be careful
apart from no service for their parts
There is no option for returns in case it turns out to be a demo piece etc
Thanks magma. I am looking at buying Samsung/Sony/Panasonic 70"+ models. I understand the no warranty part. I am looking for advice on the pricing front.
how much is the saving ?
the thing is sometimes for a small amount its not worth the headache
you might as well go to musafirkhana and buy in grey
Not sure if you should buy that stuff, but you should definitely pack that container tight with stuff you either need or are sure you can make a profit from. Weight is definitely a cost factor, but nowhere close to the money lost by shipping a 1/4-1/2 full container.
It should be relatively easy to sell space to someone, with nearly zero risk. Just make sure it's not a drug trafficker. ;)
