Intersting article : Cable quality Vs. Performance
I think only because the signal is digital hence it does not matter much, but I would like to point out that if you have electrical sources causing interference nearby you can pay higher for a better shielded HDMI cable as the interference can distort the digital data.
For analog I think good quality cables do matter since chances of distortion creeping in due to interference or even uneven resistance is higher.
For Analogue,...GOOD quality does matter VERY very much! NEVER buy cheap quality/priced cables for analogue,....u will 101% feel the difference,particularly if there are lot of electric interference nearby as in a AV-T setup, u will end up in distorted & bad qulity video & audio too.My premium quality/priced Monster cables does FULL HD 1080p video & even 1080p 3d sbs over component analogue exceedingly well/flawless ,...for the matter,i don't even find the slightest difference in video quality over my digital/HDMI or analogue/component connection on my big 51" pdp !
For HDMI, i honestly don't find much difference of video over my many different quality/priced HDMI cables...video appears fairly consistent on all of them.
